spatial join points based on one attribute in FME
  • June 13, 2024
  • 109 views
marjan_nikoukar
Hi, I want to find duplicate addresses in the data based on duplicate address numbers.
The way that I found in ArcGIS Pro is using spatial join of the layer with itself using attribute matching “address number”. This way if a point has a duplicate with the same address number in the same location, is joining with the point with the same address number and if a join count is more than 1 display, there is a duplicate.
I am looking for a way to do the same step in FME. I used SpatialFilter but did not get a result. I really appreciate any suggestion for doing this analysis.
Also, in ArcGIS Pro, it is possible to join spatially "within a distance". Is this option available in FME?
Best answer by DanAtSafe
Or use a NeighborFinder and group by the “address number”
andrewj74
Forum|alt.badge.img+7
  • June 13, 2024
maybe the “point on point overlay” would do what you are looking for? followed by a matcher
DanAtSafe
Forum|alt.badge.img+22
  • June 13, 2024
marjan_nikoukar
Thank you DanAtSafe . NeighborFinder worked.
