I have FME v2024 with a Floating License. I have Windows 10 Enterprise installed. I am almost out of space on my disk where my "Temp" folder is located.
The persistent problem I have with FME is that every time I try to open an XML file, although I do have the reader for it, I consistently get the same 6 errors. I have tried opening other files and there is no problem with those, only with XML files.
[1]: HTTP transfer error: Timeout was reached
[2]: Please ensure that your network connection is properly set up
[3]: No proxy settings have been entered. If you require a proxy to access external URLs, please ensure the appropriate information has been entered.
[4]:Failed to obtain any schemas from reader 'CITYGML' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading. See logfile for more information
[5]:Workspace generation failed. Parameter file was C:\Users\User1\AppData\Local\Temp\FME_1717067304960_7084.
Login failed (Connection Error) - Unable to connect to FME Flow.
[6]:Login failed (Connection Error) - Unable to connect to FME Flow.I checked with a colleague who has the same program/license installed, and he doesn't have this issue. I have tried different solutions found on the web, checked the license, the proxy, the reader availability. I verified that the xmls were not corrupted. None of these seemed to be the problem. I wanted to change the environmental variables of the computer, but I only have access (permission) for my user.
I already checked through the FME support webpage, but nothing could help me.
Any hints that lead me to the source of the problem would be highly appreciated.
