question : the output of changed spike remover t
  • May 22, 2024
  • 84 views
soly
Forum|alt.badge.img+3
Hello ,
Spike remover :
It cleans the lines and removes spikes and fix it  but
Changed port : the line geometry is changed .
( I mean the position of line )
i would like to fix the spike but keep the line without changing the position  of it .How could I achieve it ?
my second question :
how to find and define the part of line that has spike ?
Spike removed  create point
I would like to get also the Part of line that spiked .
FME 2021
thabks in advance .
crystalatsafe
Forum|alt.badge.img+26
Hi @soly
This article may help with your question about the SpikeRemover transformer Data QA: Identifying Spikes and Outliers with FME
If you are able to, please feel free to attach your workspace so that I can take a closer look.
Crystal
