Create pdf file from excel file
  • May 16, 2024
  • 94 views
ajhemels
Hello,
How can I make a workspace to convert excel sheets into a pdf files?
I have tried everything but nothing works.
Is there anybody who succeeded in this?
Thank you in advance!
Anne
Forum|alt.badge.img+62
You will need to create geometry objects in an arbitrary coordinate space and then create text objects in there. Pass those on to a PDFPageFormatter to place them on the page.
There’s a TableAdder custom transformer on the FME Hub that you can try, I’ve had mixed results with it myself.
ajhemels
  • May 21, 2024
Thank you! I have used the transformers tableAdder and PDFPageFormatter but I keep having issues with all the columns and rows written on top of eachother on one page. Does someone know how to solve this ?
