Utility Network (UN) (Esri) - Update Attributes
  • May 6, 2024
  • 0 replies
  • 56 views
fred.haan
Good morning,
I would like to use FME processing to "periodically" update the values ​​of certain Utility Network attributes.
This concerns the updating of data which potentially can be versioned, but I am only considering here the updating of "descriptive" (simple) attributes which are not involved in asset group assettype distribution rules and which have no impact on connectivity rules
Do you have experience of the best methodology to use and perhaps illustrate this with an example Workbench?
THANKS
