Greetings,
I’m trying to use an ETL to convert RVT files (2023) into File Geodatabase multi patch, however, the following model produces the right objects, but in the wrong location, even though when reading the RVT file directly in ArcGIS Pro, the building falls in the right place. Any clue?
