Concatenate values in groups of 5
  • March 29, 2024
  • 72 views
jeroen_hack
Forum|alt.badge.img+13
Hi fellow FME enthousiasts,
Another case i'm struggling with today.
I have a list of parcels that need to be added into a Excel template. In most cases I can sort the parcels by parcelnumber and concatenate them grouped by the Section number and write them to the Excel.
But the field in the template can fit a maximum of 5 parcel numbers. So if there are more then 5 parcels they need to be split in groups of 5.
So say i have a file with 13 parcels, I would need to split them into 3 groups (2 of 5 parcels and 1 of 3 parcels).
I can get the number of parcels with a StatisticsCalculator, but i struggle with the part where i have to split them into groups to write to the Excel. How would you do this?
Cheers!
Best answer by becchr
many ways to achieve this I think, but for example:
  • use a counter to calculate a number but do it per section (Count Domain → Section, let’s call the resulting attribute SectionCounter)
  • create a new attribute ‘ParcelGroup’ and calculate it as:
@Evaluate(@floor(@Value(SectionNumber)/5,0))
this ParcelGroup will be 0, 1, 2, … per 5 occurences in a Section
becchr
Forum|alt.badge.img+33
  • March 29, 2024
jeroen_hack
  • March 29, 2024
Thank you, this is what i was looking for!
Cheers and happy easter!
