st_geometry to (esri shape column) p
  • March 21, 2024
  • 6 replies
  • 127 views
outlook
Forum|alt.badge.img+3
Hi All,
I want to update geometry  column (esri SDE) from postgresql writer.
What I need to do ?
esri keeps the point value  like.
2D000000010000000100040001000000110000000101000090D1D3C2A00380A6E4AFBA0880A8D6B90700000000
I can reading from the postgresql as  sde.asText / asBinary    but I can not write
Best answer by nielsgerrits
I have not tried but I guess it is technically possible. What is the reason you do not want to use the SDE reader / writer?
nielsgerrits
Forum|alt.badge.img+64
When you want to write to SDE you need the Esri Geodatabase (ArcSDE Geodb) writer.
outlook
  • March 21, 2024
I want to write directly to postgresql. I am wondering  posibility..
nielsgerrits
  • March 22, 2024
outlook
  • March 24, 2024
postgresql’s writing performans better than the sde writer. Especially for bulk update.
I am using the postgresql for attribute update. But what I need to update geometry&attribute, it is updating very slowly.
Than I am wondering posssibility directly using the postgresql db.
nielsgerrits
I think this can be split in 2 parts:
  • The how to technically. I have never tried updating the geometry column, but if I google a bit it looks like it is doable.
  • The SDE integrety. You probably need to update the spatial index and the spatial extent of the featureclass, as this is done by SDE when you do a update using the SDE writer.
hkingsbury
Forum|alt.badge.img+67
  • March 25, 2024
I’d be really cautious about writing to the underlying SDE database. There are a whole heap of additional steps SDE undertakes (especially if the featureclass is versioned and/or archived). As @nielsgerrits alluded to you’ll need to update indices. I also think there is a separate table that keeps track of objectids
