What is Maximum file size that i can upload to FME Shared Resource Data Folder?
  • September 5, 2017
  • 50 views
How can i limit or configure this file size?
Best answer by erik_jan
This depends on where your FME Server is located and where your Shared resources folder is located.
If you have a FME Server installed on your own server, the size is depending on the available space.
erik_jan
Forum|alt.badge.img+26
  • September 5, 2017
