How to write an HTTP CALLER response body to a CSV writter?
armando_amador
Forum|alt.badge.img+4
danilo_fme
Forum|alt.badge.img+45
  • July 10, 2020
Hi @armando_amador
The transformer HttpCaller generates json attribute.
There is a interesting link about Tutorial-getting-started-with-json .
Is necessary to use transformers for json:
Thanks in Advance,
Danilo
  • July 11, 2020
In addition to using the HTTPCaller, you can also use the regular JSON reader and point it to the service URL. The reader will automatically analyse and expose all the attributes for you, saving some effort. To prepare the data for CSV or Excel, simply use a ListExploder on the records{} list, as suggested by @danilo_fme
However, if the service endpoints expects you to do paging, i.e. multiple requests in blocks of e.g. 10'000, then the HTTPCaller inside a looping transformer might be more logical.
