FME SQL Server Reader failing to connect . how do I check if this is a client issue? The DB is 2019 SQLServer.
  • August 2, 2023
  • 720 views
error ( Microsoft SQL Server Spatial Reader: Failed to connect using Microsoft OLE DB Driver for SQL Server. Provider error '(-2147467259)). FME server version FME Server 2022.2 Build 22765 - win64, works on desktop with same SQLServer credentials
virtualcitymatt
Forum|alt.badge.img+47
mattmatsafe
Forum|alt.badge.img+14
  • August 4, 2023
@j85824​ dependencies for the SQL Server Reader/Writer can be found below. Check if the machine hosting your FME Server engines has the OLE DB Driver 19.x installed. If not, you can download it from Microsoft and install it.
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-ReadersWriters/mssql_spatial/mssql_spatial.htm
