Can Geospatial PDF Reader Transformer read pdf maps as pdf maps (no spatial feature or table) from SharePoint and publish it as PDF on ArcGISOnline?
  • May 23, 2023
  • 31 views
jaygrg111_
I want to be able to read a list of PDFs from SharePoint and publish them on AGOL as PDF.
nielsgerrits
Forum|alt.badge.img+64
Yes this is technically possible.
  • Use SharePointOnlineConnector's to connect to SharePoint and list and download the pdf files.
  • Use ArcGISOnlineConnector's to upload the the files and share the uploaded items.
The hardest part is to get the SharePointOnlineConnector and the ArcGISOnlineConnector to work, but this is more a permissions / IT challenge than a technical one.
jaygrg111_
  • May 24, 2023
Thank you so much for your input. Much appreciated! My ArcGIS Online Connector is working, I am figuring out SharePoint Connector. Thank you!
