I have a problem to insert a gdb-Reader (ArcObject) in FME2017:
- new Workbench
- Insert Reader
properties are not relevant - run workbench
Translation stop with Message:
1 parameters (number values) were provided for the SEARCH_FEATURE keyword. An even number of parameters must be provided
It's a bug?
