Escalate different folders to load just certain data
  • May 27, 2016
  • 14 views
  • May 27, 2016
Hi
I'm not quite sure what you mean by "escalate" in this context, but if you need to read the contents of a folder structure, there is the "Directory and File Pathnames" reader which will return one feature for each file found, according to your criteria. You could then send the filename to a FeatureReader (or a WorkspaceRunner calling a second workspace) for further processing.
David
  • May 27, 2016
Look under the menu Readers / Add Reader...
