How do i convert multiple feature classes to .kmls
  • March 27, 2018
  • 11 views
I tried to convert multiple feature classes to .kml, and using a test filter assign color coding then out to a writer . but the end result is just one kml. how do i get a klm for each feature class.
danilo_fme
Forum|alt.badge.img+52
  • March 27, 2018
Hi @gislogan01,
You could generate your kml's files for each feature class using the fanout dataset in Navigator:
Thanks,
Danilo
