Unable to remove user role
  • April 25, 2013
  • 25 views
I´m trying to remove a Active Directory user role from the user roles menu.
But hhe user role are still there:)
What  am I doing wrong?
Regards
/Magnus
Best answer by kathyross
I'd be inclined to send this through to Support along with the version of FME Server in use.
Things I would try though are:
  • Add a new Active Directory user role and then delete it
  • Add a non Active Directory user role and then delete it
  • Ensure that the users assigned to the role are either deleted or reassigned to another role before deleting the role.
  • Ensure that the role to be deleted isn't associated with any Resources in the Resources tab.
  • See if Restarting the FME Server and Web Server helps
Forum|alt.badge.img+4
  • April 26, 2013
