How to get the value of a numeric attribute in a SQL Executor transformer and make use of it in a query
  • February 15, 2022
  • 32 views
Hello,
I would like to get the value that comes from a Counter transformer through the Initiator input in a SQL Executor transformer, to make a query that uses this number
Here is my request:
FME_SQL_DELIMITER ;
alter sequence cajxg_CE_sequence increment by '@Value(COUNTER)';
I tried or without the quotes, I also tried using TO_NUMBER and if I replace my attribute by a number, it works
But when I perform the query I get the error ORA-01722 (Invalid Number)
When I try to do a select with this attribute, it works
Thanks,
  • February 15, 2022
You should remove the single quotes around the number. Also you don't need to use the FME_SQL_DELIMITER when there's only one statement. Try this:
alter sequence cajxg_CE_sequence increment by @Value(COUNTER)
Just make sure that COUNTER only contains digits.
Thank you David,
But I have the same error ,
Yes, the COUNTER only contains digits,
  • February 15, 2022
Thank you David,
Try outputting the full SQL statement to the FME log with the Logger, then post a screenshot of the SQL statement here.
