Best Answer
Move and Rename CSV
  • May 11, 2023
  • 50 views
keller
Forum|alt.badge.img+7
This may be a little simple but it seems not to work for me, I have a workspace that reads a .csv file and runs a process. Ideally i would like to move this csv file once the process is complete and rename it by date.
What i have tried so far,
After the reader i created a junction and I put one process to run through the whole workspace and another arrow i put to a DateTime stamper, DateTimeConverter and created the attributes filecopy_source_dataset, filecopy_dest_dataset and filecopy_dest_filename, (based on several tutorials i have been reading.) I then use the filecopy writer to move the file. The file gets moved but the name is not changed and i get a warning that --> Ignoring the destination filename .. because the source dataset...was not a file. Destination file names are only used when the source dataset is a file.
For some reason the exact name i did set (@Value(Datum)_@Value(filecopy_dest_filename)) is shown in the written summary but not on the folder, anyone with an idea of how i can approach this?
With thanks,
Keller.
Best answer by hkingsbury
I've attached an example of how you could do it :)
hkingsbury
Forum|alt.badge.img+67
  • May 12, 2023
keller
  • May 12, 2023
Hey @hkingsbury​ many thanks for the help, it saved the day.
