Best Answer
FME Cloud configuration files
  • November 4, 2014
  • 16 views
In FME Server documentation there's a whole chapter describing FME Server config files and where to find them. But if I'm using FME Cloud... where do I find them and how can I modify them?
Thanks!
Best answer by david_r
it depends on what you want to change. Some advanced settings such as job routing and distributed installs are not available on FME Cloud.
It's probably best to contact Safe support with details of what you're trying to accomplish.
David
  • November 5, 2014
David
