Best Answer
Separate two different entities from one column
  • December 22, 2014
  • 7 replies
  • 280 views
I have a column named DateTime in a table. The format of date and time is as follows:
9/9/2009 21:23:31
25/12/1991 8:3:23
means There is a space b/w date and time. Date Month Year is seperated by '/' and time by ':'
Now, I need to seperate date and time. I want two new attributes Date and Time with respected outputs. Thanks in advance.
Best answer by takashi
The AttributeSplitter will not change the original attribute, split result will be stored in a list attribute.
e.g.
_list{0} = '9/9/2009'
_list{1} = '21:23:31'
You can then rename them with the AttributeRenamer, if necessary.
_list{0} => Date
_list{1} => Time
  • December 22, 2014
Hi, I would use the AttributeSplitter with setting Delimiter to a whitespace.
Takashi
fmelizard
Forum|alt.badge.img+21
  • December 22, 2014
I would use the AttributeSplitter (set on ' ' [space]) and remap the list elements into your output attributes.
Itay
  • December 22, 2014
Thanks for the reply.
@Takashi: I tried setting Delimiter to a whitespace, but there is no change in the output while doing that.
@Itay: I am not aware of remapping the list elements.
  • December 22, 2014
e.g.
_list{0} => Date
_list{1} => Time
fmelizard
  • December 22, 2014
exactly what Takashi means....
e.g.
_list{0} => Date
_list{1} => Time
How to split datetime column if there is no whitespace or delimiter character available. for example how to split "19960108031100" into date and time?
alc33
Forum|alt.badge.img+13
  • January 20, 2020
Hi! If the length don't change, you can use Attribute manager. You create 2 new attribute with string formula. With left or rigth function you can extract the values. Then remove the original attribute if you want.
