Best Answer
Remove Table Qualifier for dynamic workspace
  • August 14, 2018
  • 156 views
oliver.morris
Forum|alt.badge.img+14
Hi, I have a Schema Source and Destination in a database and the Feature Type names contain the Table Qualifier (e.g. <prefix>.<table_name>). One one side it is dbo. on the other it is tab.
I tried to follow the guide https://knowledge.safe.com/articles/1156/dynamic-workflow-tutorial-destination-schema-is-de-3.html but with this same data source you can remove the prefix as an option. With SQL Server it doesnt appear to be possible. How do you get round this?
Many Thanks,
Oliver
Best answer by oliver.morris
got it @ReplaceString(@Value(fme_feature_type),"dbo.","tab.",FALSE)
oliver.morris
  • August 14, 2018
  • August 14, 2018
You can use a StringReplacer to remove the schema name, something like:
Text to replace:
oliver.morris
  • August 14, 2018
Text to replace:
Thanks David
