CityGML writer fails to write CityGML from CityGML
My workflow is pretty easy, I drag and drop a CityGML file in the workbench and then add a CityGML writer and connect it. FME proudly tells me it wrote features, but when I open the file there's no geometry. Do I have to add a bunch of transformers?
Variations tried on reader:
- all features
- single merged
Variations tried so far on writer (feature type definition):
- all of them
More info:
- the source CityGML file is fine and displays without errors in the inspector
- no errors are reported during the translation
Best answer by lars_de_vries
Have you tried to set the writer to 'Dynamic'?
At the Schema Definition Name you should select the reader.
Forum|alt.badge.img+49
Any chance you could share your source data here? That'll make it easier to find out what's going on.
lars_de_vries
Forum|alt.badge.img+10
The problem was elsewhere. I cleared out my temp files and rebooted a few times and now it works. A problem where some textures showed as transparent red-dotted areas in the inspector went away as well. "Dynamic" however would be the right answer if everything else worked correctly.
