Using FME Server 2021.
Uploaded workspace that has no problems to run on Desktop. When running on FME Server it fails with the message:
FAILURE
INCLUDE -- failed to evaluate TCL expression ` FME_CleanseFMEUUID {StringPairReplacer_9f3b9011_1d33_4123_9fa5_4f7dd23e28558} ' -- invalid command name "FME_CleanseFMEUUID" while executing "FME_CleanseFMEUUID {StringPairReplacer_9f3b9011_1d33_4123_9fa5_4f7dd23e28558} "
The difference is that I'm using Data Interoperability extension for ArcGIS desktop build 21627 to create my worbspace.
