DGN levels not the same as in Microstation Connect.
  • November 19, 2020
  • 54 views
Hello,
I have a few DGN files where I want to separate the data depending on what layer they belong to.
In Microstation I can see that the objects in the file is on a level, ex "Växel spårspärr bef V". MicrostationLevelBut when I check the data in FME inspector all igds_level_names and fme_feature_type are set to "ECT_DGRM_RFPT_MARK".
FmelevelAnyone know why they are different and how to solve this?
  • November 19, 2020
Exactly which dgn reader are you using, and how is it configured?
When I use the "Bentley MicroStation Design (V8)" reader and make sure that the reader parameter Group Elements By = Level Names, then I usually get the results you seem to be looking for.
  • November 19, 2020
Hi David,
Yes this is exactly how I'm doing it, and usually it works fine.
This is the first time I am working with cells, if that has something to do with it.
