I am merging data from and existing ESRI File Geodatabase with data form excel spreadsheet using globalID. I then want to write that data to new ESRI File Geodatabase, preserving the GlobalID from the existing fGDB. I can see this is possible in SDE. is there a way I can do this in non-SDE fGDB. I am using FME version 2019.1
Page 1 / 1
Unfortunately I don't think that is possible, but please consider voting for the idea here:
https://community.safe.com/s/idea/0874Q000000j0IbQAI/detail
@ste18302 Preserving GlobalIDs is not yet possible for File Geodb (as @david_r mentions above). However, I think it is possible to convert your GlobalIDs to a GUID and then write those, then convert those GUIDs to a GlobalID. I couldn't find anything newer than this but it might give you some ideas.
