We have a ESRI FGDB file available with .z02 file extension. Is it possible to read FGDB data on FME without ARCGIS ? Can we upload FGDB file to Oracle spatial database through FME ? Any pointer on this would be appreciated
Best Answer
View/Read ESRI FGDB data through FME
Best answer by rahulsharma
Hi @cakila and @vasuki
Can you clarify if you are indeed using an Archiving file?
Currently, with FME Desktop 2019 we support all the following (7z, 7zip, rar (except v5), rvz, tar, tar.bz2, tar.gz, tgz, zip )
- I agree with erik_jan as well, that in order to read the archiving files all files must be available, its possible that your data is incomplete.
- Using FileAPI Geodatabase reader, you will be read most of the features except Relationships.
- The Error code that you have mentioned means that the file was not located, if you look closely in your log file, you should see some portions getting extracted in C:\\users\\<user>\\AppData\\Local\\Temp\\
- I have tried reading some data(v10 and 10.1) with *.zip.001 archiving in FME without any issue. If you also attach your log file that would be great.
