Hi! I have a workspace that converts LAS into Recap using a pointcloudlasclassifier before writing out to Recap. This workspace runs 100% flawless on desktop. When publishing to FME Server however, the workspace always fails the first run after logging into a new session in the browser. When running the workspace the second time (and following runs) without editing any parameter it runs successfully. Any ideas what can cause this issue? It seems that it is the rcs-files (which are written to a subfolder) that is causing the workspace to fail.
