SQLite Database - Data Extraction from HTML
  • April 5, 2023
  • 8 replies
  • 111 views
abnan0001
Forum|alt.badge.img+9
I have a Data collected using Survey123 but sending data has issue and it was stored in android device only , so the format will be in sqlite database.. I want to extract the data from SQLite database and im able to read and see the data but not able take it into XML Fragmentor ..May be im doing some wrong..
I have attached screenshot and workspace ..
Need Guidance and advice to fix this
Thank You
Need expert advice
BDCError
Data
Best answer by redgeographics
I have used json formatter and also JSON fragmenter..
It doesn't expose the attribute of the body message...It gives missing ..Kindly guide
Thank You
JSONFragmentor
That's probably because you need to dig deeper in the JSON structure. Using [*][*] as the JSON query and then followed by a JSONFragmenter gives me more results.
You'll also need to expose any attributes that are created by the JSONFragmenter (it has an Attributes to Expose parameter) as FME won't do that automatically
Forum|alt.badge.img+62
That's not XML, but JSON, so try the JSONFragmenter (so this probably also means the HTMLToXHTMLConverter is not necessary either)
abnan0001
  • April 5, 2023
It gives me error as " No results" when used Json fragmentor
Kindly Guide me , How to accomplish
Thank You
abnan0001
  • April 6, 2023
Thank You
JSONFragmentor
  • April 6, 2023
Thank You
JSONFragmentor
Forum|alt.badge.img+46
  • April 6, 2023
Thank You
JSONFragmentor
As @redgeographics says, you'll need to change the JSON query, e.g. for the bird data
json["BDC_General_Baseline_Survey_V8"]["AddBird"][*]
Then expose the attributes
abnan0001
  • April 6, 2023
Thank You for the Guidance..
I was able to expose the attributes for 2 reading which i require for Birds and Mammals , Florainfo and otherinfo from JSON Body whereas for Reptile and other associated with it are not showing and its being rejected..
I have added separtely JSON fragmentor to expose..
Need your Guidance , I have attached excel and red colour details for reptiles , I want to expose from JSON Body
Kindly Guide
Attached Workspace and Excel Sheet for more details
Thank You
abnan0001
  • April 6, 2023
Kindly Guide
Thank You
Excel Attachment for the required information(Copies from JSON Body) Highlighted in Red to be exposed
any suggestion
abnan0001
  • April 7, 2023
Thank You so much ..
I was able to Extract the information
