I am getting an error message
  • January 21, 2020
  • 3 views
I am getting the following error message when I try to connect a reader to a read-only Arc SDE connection "Unable to read from the table/feature class 'GDM.GasValve'. If 'GDM.GasValve' contains a class extension, make sure it is registered on this computer"
I would appreciate if i can get any help with getting round this.
Best answer by jovitaatsafe
Hi @muyiwasami,
Have you already seen this answer by srayford on a similar question? Installing ArcSDE Command Line Tools seemed to work for them when they got this error. Hope that helps!
jovitaatsafe
Forum|alt.badge.img+11
  • January 22, 2020
Hi @muyiwasami,
