Hi Danilo,
I'm gonna have to check if I can share the data.
The workflow that I actually needed is that I have an FBX and DWG as my reader. I needed to clip my FBX using my DWG which serves as an AOI or clipper.
Do you think this is possible?
Thanks in advance.
You'll need to find a way to transform your 3D surface features from your FBX to 2d road polygons. There's a nice discussion on how you might do this in this thread: https://community.safe.com/s/question/0D54Q000080hMFaSAM/is-it-possible-to-convert-a-surface-to-3d-pts-lines-or-polygons
Is it possible to clip an fbx if I have a corresponding AOI (in dwg format)?
