I have a hosted feature view (that I set the view definition for) on ArcGIS Online that is linked to a hosted feature service. When I add the hosted feature view as the writer in FME and set Truncate First to YES, it truncates/deletes all the data in the hosted feature service and not just the data that is in the view. Is there a way to get around this, as I expect when I truncate a view, it would only truncate the data that is visible in the view. @carsonlam
