Hi, I have looked into several posts here but not really found similar results. I tried to write my DWG into a Map 3D dwg to for example write attributes like creation instance into my DWG which worked really well:
Writing attributes to AutoCAD User Properties (safe.com)
However, I want to be able to add / edit attributes for my features that are readable by Bentley Microstation . Every result I found is DGN but the format must be DWG. Is there any way to write attributes to a DWG which is readable in microstation? Result above has no attributes or properties so doesn't work. Originally the results I don't want in block but that rule can be bent so every single features can be a block if that is the only way. When I inspect my DWG in Microstation it doesnt have my written attributes, I can only see them in AutoCAD. I want similar like example: In my results with id and count doesnt exist in microstation and only geometry information can be found in properties.
Lets say i have 3 points, all have StreetName StreetNo, I want written to DWG and be able to read those results in properties in Microstation.
Read alot about maybe solving it with shared parameters or similar but have not succeeded.
