I have an excel file with lat/long coordinates and I'm trying to create points based on them in a file geodatabase. The geometry is being created but I keep getting an error when trying to view the attribute table: "A column was specified that does not exist." I've checked that all the columns are green in the file gdb writer.
If I replace the file geodatabase writer with a shapefile writer everything works fine. Can anybody tell me how to figure out what is going on?
Using FME Workbench (Form now?) 2020.1
Thanks,
Mike
