How do I assign attributes to line segments on the boundaries of polygons based on the polygons they bound
I have a road network with left side and right side reporting area attributes. I'm trying to figure out how to determine how to assign the left/right side when a line falls on a boundary between two reporting areas. There is no danger of overlapping areas as they are spatially discrete objects. I've tried several methods, but each seems to have drawbacks. Any suggestions?
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
