I would like to combine existing text to the point attribute (z-coord). In the picture there is point and line string to point to it. In the other end of the line, there is a text object. All object are separate ones. Only the each object coordinates gives the hint, which text belongs to which point. Anyway Happy New Year from Finland despite the latest ice hockey result. ;-)
