Attribute Manager (Import Wizard) - Possible Bug as Attributes are sorted by default
  • May 9, 2023
  • 73 views
sameer
Forum|alt.badge.img+19
FME(R) 2022.2.5.0 (20230329 - Build 22795 - WIN64
Hello
Just detected this possible bug when importing Attribute Names / Values using Attribute Manager. The Names are pre-sorted and the "Sorted" option unticked as shown below.
imageOnce the dataset has been imported (Select * for Input/Output/Values) the values are set as shown below. Was I not meant to see the actual values or have I misunderstood this part? Looks like the Attribute Names have been set as values. If that's intended then what could be a potential use case?
Original Attribute Names order / Table structure as defined in the Postgis Db
Thanks
Sameer
Best answer by kailinatsafe
Hello @sameer​, thanks for posting! I was able to reproduce the sort issue on import from dataset in the AttributeManager, I will file a ticket with our development team to have this addressed!
I think to use or access attribute values on import, you'll need to change the selection 'attribute values' in the import wizard:
ImportFromDataset_AttrManager
kailinatsafe
Forum|alt.badge.img+23
  • May 9, 2023
