Dose FME require Arcgis Pro or Server in order to be able to write in file geodatabase?
  • March 4, 2021
  • 25 views
alaa_flaifel
ss
nielsgerrits
Forum|alt.badge.img+64
I believe you can use the Gdb Open API writer to write to gdb without license.
GdbFormatsI know there are differences but not sure which.
caracadrian
Forum|alt.badge.img+23
  • March 4, 2021
It says you don't have an Advanced ArcObjects licence. Or that you don't have a 64bit one.
Try 32bit FME if it's the second case.
alaa_flaifel
Thank You
@alaa_flaifel​ Full details of compatibility and requirements here: Notes on FME and Esri Versions and Compatibility
