Oracle xmltype and ArcGIS sde
  • May 15, 2023
  • 23 views
francis_m
Forum|alt.badge.img+8
I read an Oracle Database with "esri SDE" connection file.
I need to update the reader. We now have a new Oracle table that contain a new column and the datatype of that column is "xmltype".
With a Oracle Reader or SQLExecutor, I can read the "xmltype" data. But if I read the data with "SDE", the column is not there. Like SDE don't understand "xmltype". Any idea ?
trentatsafe
Hi @francis_m​ ,
The fact that you can read it in using Oracle Reader and SQLExecutor makes me think that the table isn't registered with the Geodatabase. Just to confirm this is a Feature class that is registered with the Geodatabase? Are you able to share a screenshot showing the fields as viewed in ArcGIS or share with us the XML Workspace Document that contains the schema of the table you are attempting to read?
francis_m
  • May 24, 2023
Hi @francis_m​ ,
Hi! thansk for the answer. The Oracle database is not an SDE database. It's just a Oracle database. SDE connection file can connect to Oracle even if the table is not registered. I read the table and create the geometry. The field viewed in ArcGIS is visible but no property. I will work with sql executor to get back the data. it's my workaround.oracle_tbl_with_xmltype_in_arcgisoracle_tbl_with_xmltype_in_arcgis_dataoracle_tbl_with_xmltype_in_oracle
trentatsafe
Hello @francis_m​ ,
The data type not showing up is odd, i'd suggest reaching out to Esri regarding that. With regard to FME, we would recommend using the Native database format for reading/writing unregistered tables that are in your Geodatabase. The reason being is some of the data types may not be supported via the ArcGIS libraries that we use.
