FME Server License JSON FILE request has very slow response
  • April 25, 2019
  • 18 views
adieporter
Hi all
Just wondering if Has anyone has experienced very slow request times when downloading the licensing JSON request file?
We have a new install of FME Server 2018.1 on linux RHEL7. Its offline so we must download the license request JSON file. We requested via the web-ui and it took nearly 10 minutes to return the file. We tested using the REST API test page with similar timings. Other REST calls seems to work fine.
We've done a number of installs the mirror this onto different environments with out encountering and delay.
The logs do not seems to indicate anything adverse.
A bit of a head scratcher but thought I'd see if the hive mind could help.
Cheers
Adie
  • April 25, 2019
Yes, I can confirm that it's always been super slow for me as well. I have no idea why...
adieporter
  • April 25, 2019
Thanks David
Good to know its not just me.
Its doing what it needs to just super slow, We have three other environments all seemed fine.
Hopefully not a sign of other issues
Cheers
Adie
