Converting 2D objects to 3D in Revit
  • August 21, 2020
  • 34 views
Hey, we are working on ceiling grids in Revit and heard about FME can convert 2D grid objects to 3D and furthermore creat ceiling plates. Is there anyone who have worked on this before? I'm new to FME :p
sigtill
Forum|alt.badge.img+25
  • August 25, 2020
Hi @lj_norcon​ Can you supply a small dataset and perhaps some screenshots of the wanted result? Using the 3DForcer to set a Z-value and an Extruder to set the thickness and a SolidBuilder to create a Solid is an often used method to create 3D objects from 2D-lines.
