how to create line string from json point array
  • June 29, 2017
  • 131 views
f.kemminje
Forum|alt.badge.img+11
Hi team.
I extracted json from http caller. extracted json file attached. json.txt.
in this json there are array of points. the path of these points is. ucan see these points after "paths"
(text string)
routes{0}.routeOptions{0}.optionAttributes.spatialReference.geometry.paths{0}.array{0}.array{0} routes{0}.routeOptions{0}.optionAttributes.spatialReference.geometry.paths{0}.array{0}.array{1} routes{0}.routeOptions{0}.optionAttributes.spatialReference.geometry.paths{0}.array{0}.array{2} routes{0}.routeOptions{0}.optionAttributes.spatialReference.geometry.paths{0}.array{1}.array{0} routes{0}.routeOptions{0}.optionAttributes.spatialReference.geometry.paths{0}.array{1}.array{1} routes{0}.routeOptions{0}.optionAttributes.spatialReference.geometry.paths{0}.array{1}.array{2} routes{0}.routeOptions{0}.optionAttributes.spatialReference.geometry.paths{0}.array{2}.array{0} routes{0}.routeOptions{0}.optionAttributes.spatialReference.geometry.paths{0}.array{2}.array{1} routes{0}.routeOptions{0}.optionAttributes.spatialReference.geometry.paths{0}.array{2}.array{2}
here
array{0}.array{0} =x coordinate
array{0}.array{1} =y coordinate
array{0}.array{2} =z coordinate.
using xy cordinate value i want to create a line vertexes using point connector.
But i am not able to extract the array of coordinates from json .
Please help me. I have attached my fmw file.
Best answer by david_r
Try the following JSON query in the JSONExtractor:
json["routes"][0]["routeOptions"][0]["optionAttributes"]["spatialReference"]["geometry"]
Then use a GeometryReplacer on the resulting JSON object with geometry type "ESRI JSON". I also suspect you'll want to use a GeometryRefiner and the ElevationToMeasureCopier (from the FME Hub) followed by a 2DForcer to move the Z-values to M-values on the resulting geometry.
You can find the JSON query documentation for FME here:
http://docs.safe.com/fme/2017.0/html/FME_Desktop_Documentation/FME_Transformers/Transformers/jsonfragmenter.htm#JSON_Queries
I can also recommend this site where you can construct your JSON query string online while getting live results:
http://www.jsonquerytool.com/#/JavaScript
  • June 29, 2017
  • June 29, 2017
Btw, thanks for giving us such a clear and reproducible case to work with! :-)
f.kemminje
  • June 30, 2017
Thanks David.
I used below python code(iteration thru points)
then list exploder
vertex creator
point connector
this is the long process
i will replace yours now.
you are Genius.
import fme
import fmeobjects
import math
def frq(feature):
    a=0
    b=0
    while True:
        ol=feature.getAttribute("routes{0}.routeOptions{0}.optionAttributes.spatialReference.geometry.paths{0}.array{"+ str(a)+"}.array{"+str(b)+"}")
        if ol is None:
            break
        feature.setAttribute("_list{%d}.x" % a, str(ol))
        b += 1
        print ol
        if ol is None:
            break
        print ol
        feature.setAttribute("_list{%d}.y" % a, str(ol))
        b =0
        a += 1
  • June 30, 2017
Thanks David.
then list exploder
vertex creator
point connector
you are Genius.
import fme
import fmeobjects
import math
def frq(feature):
    a=0
    b=0
    while True:
        if ol is None:
            break
        b += 1
        print ol
        if ol is None:
            break
        print ol
        b =0
        a += 1
Not a genius at all, just a long time user :-) Glad I could help.
