I want to access the property sets a of a dwg in FME.
I enabled the 'Civil 3D and CAD Entities' option in the Schema Mode of the Civil 3D Reader.
When i attach an inspector to the reader, I get a fatal error.
AutoCAD Reader: An error occurred for dataset 'C:\\Users\\wisbeja\\Documents\\AWV\\FME voor dataconversie DAVIE\\voorbeeld data\\DWG solid and prop set\\small_test.dwg', in function AutoCAD2004Reader::read. Exception thrown: 'Invalid ResBuf' (Invalid ResBuf)
dwg file is attached.
When I read the dwg with a dxf/dwg reader the inspector works. But I guess I am not able to access the property sets with this reader.
Any suggestions?
Jasper
