I have a File Geodatabase (ArcObjects) Writer that points to a FileGDB I want to update. When the Writer Mode=UPDATE, the feature count from Reader to Writer is very slow, at a rate of ~1 feature per second. If I were to perform DELETE first and then INSERT as a way to update, then it's very fast.
Why might UPDATE be so slow? There are 2 bottlenecks I think might be occurring:
- The field I'm updating on is not a unique field - This field represents a "tile" of records, by which I want to update on a tile-by-tile basis.
- Grid 1 is set to 100. When updating database tables, it's recommended that one removes spatial indexing, perform update, then recreate the index. Is there a way to do that with the FileGDB ArcObjects Writer? Might I have to use PythonCaller to call arcpy.RemoveSpatialIndex()?
