Issue with FeatureCollection in INSPIRE GML
  • July 27, 2017
  • 155 views
oscard
Forum|alt.badge.img+22
Good morning.
This week has been released the new INSPIRE validator:
http://inspire-sandbox.jrc.ec.europa.eu/validator
This tool allows you to validate a GML file.
I have several GML that I got using the INSPIRE GML writer in FME. To validate them, I just checked them against the XSD provided by INSPIRE. That validation was always OK.
But with the new validator I'm getting this error:
cvc-elt.1.a: Cannot find the declaration of element 'gml:FeatureCollection'.
I have attached a sample of my GML. There is a FeatureCollection tag...
Does anyone know if I have to change something of the INSPIRE GML writer to build a proper FeatureCollection?
Thanks!
Best answer by lars_de_vries
Hi @oscard,
it could be an error in the GML, in the Writer and in the Validator.
You should have a look in the XSD to see whether the FeatureCollection tag is declared there. If it is declared, it might be an error in the Validator. If not, there might be a problem in the Writer.
Hope this helps.
lars_de_vries
Forum|alt.badge.img+10
Hi @oscard,
Hope this helps.
oscard
  • July 27, 2017
Hi @oscard,
Hope this helps.
I needed to add more elements to the schemeLocation URL parameter of the writer:
http://www.opengis.net/wfs/2.0 http://schemas.opengis.net/wfs/2.0/wfs.xsd http://www.opengis.net/gml/3.2 http://schemas.opengis.net/gml/3.2.1/gml.xsd http://inspire.ec.europa.eu/schemas/cp/4.0 http://inspire.ec.europa.eu/schemas/cp/4.0/CadastralParcels.xsd
With that, the new validator gives the OK to my files.
Thanks for your answer. It took me to the right path.
