Loop Process
danilo_fme
Forum|alt.badge.img+45
Hi Team,
I have a dynamic CSV file with the following structure:
Day 01102018
Point1
Point2
Point3
Time 01:00
23
40
4
Time 01:30
43
24
21
Time 02:00
130
49
10
Is necessary to identify the lines 1-2-3 and in each node (
Time XXXX ) realize the merger with the Points. The Loop process will be
 good in this case?
The Image bellow, is my goal:
Attached my example file -
Thanks,
Danilo
jdh
Forum|alt.badge.img+28
  • October 3, 2018
I would personally read it line by line with a text file reader and then use either variables or adjacent features.
See https://knowledge.safe.com/questions/3346/translating-a-polygon-from-poly-osmosis-polygon-fo.html
Or https://knowledge.safe.com/questions/65092/connect-lines-without-common-id-by-order-in-file.html?childToView=65116#answer-65116
danilo_fme
  • October 3, 2018
Hi @jdh
, First thanks your attention and answer.
I tried to use the transformer AttributeCreator from this Link Attribute Creator but without success.
Could you help me?
Thanks, 15379-textlinebreaks.fmwt
jdh
  • October 3, 2018
danilo_fme wrote:
Hi @jdh
Could you help me?
Can you repost your goal? I have a broken image.
jdh
  • October 3, 2018
Here's a variableSetter/Retriever example. I expanded the data to allow for multiple dates, if that is not the case you can simplify things.
textlinebreaks.fmwt
  • October 3, 2018
The link to your goal image is broken. Please post it again.
danilo_fme
  • October 4, 2018
textlinebreaks.fmwt
Thanks your help and attenction in this case. @jdh
It was perfect.
gio
Forum|alt.badge.img+15
  • October 4, 2018
Another (and fun) way to read such a simple structured file would be to realize that you can identify the attributes by using div and mod functions on the txt_line_number.
The first set would then become attribute names and all subsequent sets will be attribute sets.
