Classification Point Cloud data collected by Car mounted device.
  • June 11, 2019
  • 56 views
amolparande
Hello FME User,
Does any one having experience to process LIDAR or Point Cloud data collected by Car mounted device.
I need to classify the data in to Road Surface , Building , Tree trunks, electricity pole along with Road
The bad news is in point cloud we don’t have any calcification values it’s “Zero” everywhere.
Can any one please guides me. Unfortunately data can not be share.
Best answer by jlutherthomas
Hi @amolparande
I don't think there's going to be an easy way to do this - when I've done a similar project in the past I had to manually identify the coordinate bounds and intensity values for the object(s) I was trying to classify, then use a PointCloudFilter to split the point cloud up into those features.
Hi @amolparande
amolparande
  • June 12, 2019
Hi @amolparande
@jlutherthomas Thank's for your input
can you please give me some inputs how can this be done ?
or any workbench you have for reference ?
I don't have any workspaces for reference.
You would need to spend time manually interpreting and classifying your data using the components you have available if you want to be able filter it different features in FME .
Unfortunately I don't think this is going to give you very precise results (and will be time intensive) due to the data values you have. I don't know whether your data vendor is able to do any classification for you?
  • July 13, 2019
Hi @amolparande,
Maybe this could be helpful:
https://knowledge.safe.com/articles/1096/color-and-point-clouds.html
