Copying table from postgis to postgis as FME server job
  • April 27, 2018
  • 7 views
dollargis
The task is to read a postgis table (fully qualified namespace.tablename) from one database and write it to another database into the same namespace and with the same tablename. Table name and namespace are not known beforehand but get submitted in the form namespace.tablename as a parameter at runtime
I have successfully created this JobSubmitter workspace:
which, according to this logfile runs successfully.
The server workspace postgis2postgis.fmw looks like this:
and when run, fails for reasons unknown to me. The server log is this:
I cannot figure what I've misconfigured here, so any help would be greatly appreciated.
Best answer by dollargis
Shame on me, but this works! I had made two mistakes:
* Switched off error logging
* and therefore not seen that I had forgotten to enable the postgis extension in the database
dollargis
  • April 27, 2018
