Child version not automatically after "reconcile and post settings" in writer
  • January 24, 2019
  • 44 views
I’m having problems with SDE writer with a “Versioned Edit Session” transaction type in my workspace. The workspace in question is initiated by Workflow Manager. A child version is created in our flow and the name of this version is passed along as parameter value. I’m using a writer, with three feature types, with the following settings:
What do I expect:
The data is written to the child version. If writing to the tables succeeded, then the child version is reconciled and posted to the parent version. After posting, the child version is deleted. When the writing fails, the child version is not posted to the parent and is automatically deleted.
What do I have at the moment:
The data is written to the child version. If writing to the tables succeeded, then the child version is reconciled and posted to the parent version. After posting, the child version is not deleted. When the writing fails, the child version is not posted to the parent and is not automatically deleted. The following error in shown in the translation log:
When the child version is made, we made sure that the code does not create locks on the database by adding "arcpy.ClearWorkspaceCache_management()" at the end of the code. We use the function "CreateVersion_management" from the arcpy module to make a child version.
Can someone help me with this issue?
Thank you in advance!
trentatsafe
  • January 28, 2019
Hello @gabriella_alexa,
Unfortunately, I believe what you are encountering is a previously known issue in regards to Posting and Reconciling, followed by deleting the Child version. The reason you are seeing this error is as a result of how the Posting/Reconciling + Deleting a Child version is carried out.
In order to do this, it would require a 2 step process. One example would be to use a WorkspaceRunner transformer - where you run the workspace and then delete the Child version using a Python Script(PythonCaller) if successful. You could also try a Shutdown Python script as well, that might work too.
Let me know if that helps!
