I am new to FME (my first post!). So, I am just playing around trying to learn the software a little (we are planning on using it to load a large amount of CAD data into GIS). I am using FME 2018.1 to write (insert) into one versioned feature class within a 10.2 esri SDE in Oracle. Everything looks fine when I look at the version in ArcMap. But I am getting an error at the end of the process.
A BADNEWS error shows up in debug logging -- similar to the one in this post :
https://knowledge.safe.com/questions/76727/error-running-translation-after-what-appears-to-be.html
I am using FME 2018.1 32 bit on win 7
Suggestions?
