SmallWorld - More Options
  • May 24, 2019
  • 5 replies
  • 35 views
pratap
Forum|alt.badge.img+12
When I looked at the below link
https://knowledge.safe.com/articles/48316/importing-into-smallworld.html
I came across the options "Export to FME" and "Import from FME" in Folders dialogue box
Does anyone used these options (refer image at red polygon)???
If yes could you kindly provide some information about uses/functions/requirements to use them
Thank you
Pratap
zzupljanin
Forum|alt.badge.img+5
  • May 24, 2019
Hello,
so these two slots in explorer in sw are here for you to only import/export only selected collections of objects.
You just drag and drop collection from My Datasets. All objects inside it will get:
1. Added as writer in FME (if you add collection to Export to FME)
2. Added as reader in FME (if you add collection to Import from FME)
Of course, you need to add SW4/5 Reader or Writer and choose Table list (only collection that are in these two slots will be shown).
This is particulary usefull when you want to use only few objects of sw in fme (You don't have to read whole database). Then you:
1. Select objects of interest in SW
2. Put them in Scrapbook
3. From Scrapbook drag collections (one by one) to Import from FME
Try it, and give us your insight.
Cheers.
pratap
  • May 27, 2019
Thank you @zzupljanin
Could you kindly explain further
Pratap
zzupljanin
  • May 27, 2019
Pratap
Certainly,
Please look at the example.
I have features of interest (in Scrapbook) that I want to work with in FME.
I'll just drag them to Import to FME.
Inside FME: only selected collections are visible as tables to read. When running workspace, only these features went trough Reader although SW database consist of thousands of data.
Like I've said. Very practical, very timesaving, you don't have to read whole database if you work only with some data.
pratap
  • May 28, 2019
Certainly,
I have added from scrapbook to "Import from FME". It is same as per your screenshot. But I'm not sure how to bring this collection as reader in FME???
zzupljanin
  • May 29, 2019
It's the same procedure as in https://knowledge.safe.com/articles/48316/importing-into-smallworld.html
1. Add SW Reader
2. Go to parameters
3. Go to Table List: Pick tables to read
